reading the rest of the posts i think you all need to try the siren before removing the dash or tearing it apart.
Should just pull off from memory. Is the siren located between the wipers or to the side slightly, and how far back is it?
I have found the siren under the scuttle, however it doesn't move very much, Did anyone else find this and did it solve it?
My squeak/rattle on seems to happen when taking corners....sounds like it's in time with the fan(s) in the dash and mostly under the centre and left hand vents!
Anyone any ideas that won't involve a dasherectomy?
Haven't got round to having a look at the siren yet but mine sounds like its the dash where it meets the windscreen esp when going over bumps.Any one else got this:confused
Hi Guys, Ive spent the last couple of evenings in the dark..with a torch and in the rain lol trying to find a rattle coming from somewhere in the boot. Ive had/got every plastic trim off and found...
The metal clips that hold the trim on around tailgate glass were loose, even found some in the actual tailgate causing a rattle
The plastic trim where the spare wheel is, the nuts are missing cousing this to rattle too lol
After a couple of road tests there was still rattles..
The tailgate handle mechanism, the rods are really loose. Is this common?
Lubricated most of the parts but it still rattles.
If anyone could advise me that would be great as this is my first Seat. Apart from the rattles the car is ace.
try shaking the seats see if thats the rattle or not if it is bend the tabs that the seats fold and clip into cured mine. also i had a rattle in the boot and i adjusted the rubbers that the boot closes onto and it sorted the problem.
Cheers for the reply, Ive put some tape over the seat catches which has cured the squeak! Will have a look again at the tailgate over the weekend and try adjusting the rubbers.
