Get some light weight wheels on. Lower rolling mass = more performance.
Air ride next lads?
Great for track..![]()
You'd be better off with 17's as track day wheels the Tyres are cheaper.
You need one there awesome had one in the Lcr now the R32 yes you can clear codes reset the throttle body loads more , come have a play with mine and the liquid gauge before you buy one![]()
Yeah the G/S reading will be the same vag com use so will show the same they also show the bhp and torque it converts it from the G/S made , there pretty close as well to a RR session
In my opinion the 1.2's only look good in the 18x9 fitment
If the car is being used for track, looks don't matter as much as usefulness.
I have 18 x 8.5" (same as standard) Pro Race 1.2's on mine, ET45 and on hard corners when on the track, it rubs the inner arche liners which does my tit in. Standard wheel is ET52 I think so the minor drop even with the KW V3's at the hardest setting combined with a large offset or larger width wont work as a good compromise.
