Hi all! Just had a revo remap on sat, amazing but got in car tonight & the engine management light has come on!! not buzzin at all! i`ll be ringing revo first thing, but any thoughts why? cheers.
Do you have an aftermarket exhaust? Did you get Stage 1 map only?
It will probably be a cell light for your emissions. It will either need to be mapped out (Stage2) or a spacer put on the post cat lambda sensor. Common issue and nowt to worry about depending on your answers to the first two questions![]()
r6_allan;40849 case as Simon saidup Revo unless you have access to VCDS and can scan for the exact fault code. Could be unrelated but unlikely. Prob best to return to Revo dealer anyway.[/QUOTE said:Defo mate! Ill ring 1st thing, can i damage anything?
was your car set up and logged when the map was put on?
or did the dealer just upload test drive and say its ok?
