Is Cruise Control Economical?
DavidS
119
I know this is going to sound pretty obvious but:
Check your tyre pressures are correct (think it should be 29psi for fronts & 32 psi on rears)
and
Check your wheel alignment is correct
if either are out, this makes hell of a difference to your MPG as your tyres are not rolling as efficiently as they should....
check tyre pressures weekly & have your wheel alignment checked every 6 months.
David, when was the last time you checked either?
I had my wheel alignment done 6 months ago it was way out and my car had eaten a set of front tyres to the point they were bald on inside edge & had 5mm left on outside edge. It was stepped wear, so had it done & got 2 new tyres.
Had wheel alignment checked again this week in addition to my MOT & it was out, again, both front & rear. So had to be adjusted again on the 4 wheel hunter machine.
Car feels a whole lot better now & retuns slightly better MPG than it did before the MOT :)
I check my tyre pressures prior to any long journey (along with lights & levels checks).
Wasn't aware of the wheel alignment issue however, thanks for the head up mate. I'll check my tyres in the morning.
Does anyone know what mpg a PD170 Leon should return on a long journey?
AndyG_TSi
1,174
East Manchester
Here is the wheel alignment printout from yesterday, both before & after are shown, the red indicates where it was out.
sorry for the picture quality, it was taken on the phone
picture.php
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
When I had a PD170 I managed to scrape an indicated 50MPG on a long run (400 miles or so) a few times. I seem to remember that an indicated 50MPG is about as good as it gets on a PD170.
600 miles to a tank is another goal for PD170 owners too.
