I know this is going to sound pretty obvious but:
Check your tyre pressures are correct (think it should be 29psi for fronts & 32 psi on rears)
and
Check your wheel alignment is correct
if either are out, this makes hell of a difference to your MPG as your tyres are not rolling as efficiently as they should....
check tyre pressures weekly & have your wheel alignment checked every 6 months.
David, when was the last time you checked either?
I had my wheel alignment done 6 months ago it was way out and my car had eaten a set of front tyres to the point they were bald on inside edge & had 5mm left on outside edge. It was stepped wear, so had it done & got 2 new tyres.
Had wheel alignment checked again this week in addition to my MOT & it was out, again, both front & rear. So had to be adjusted again on the 4 wheel hunter machine.
Car feels a whole lot better now & retuns slightly better MPG than it did before the MOT :)
I check my tyre pressures prior to any long journey (along with lights & levels checks).
Wasn't aware of the wheel alignment issue however, thanks for the head up mate. I'll check my tyres in the morning.
Does anyone know what mpg a PD170 Leon should return on a long journey?
Here is the wheel alignment printout from yesterday, both before & after are shown, the red indicates where it was out.
sorry for the picture quality, it was taken on the phone
picture.php
When I had a PD170 I managed to scrape an indicated 50MPG on a long run (400 miles or so) a few times. I seem to remember that an indicated 50MPG is about as good as it gets on a PD170.
600 miles to a tank is another goal for PD170 owners too.
