You'll need ten to do it the same way I did. I can't remember the size a got as I didn't buy them. You'll need two larger ones from the core. Don't use the crappy T-clamps or you'll leak like a sive.Just wondering how many jubilees you used and what size?
I just bought the leg size they come as standard and cut it down. When are you fitting it?Also what size is the 45mm silicone hose to charge pipe in length?
The passenger side pipe work connects to standard plastic map pipe. The extra 45 alloy and silicone join to the charge pipe to do away with the oem pipe.
If you want any pics let me know
So if its connecting to the oem pipe then that's why you purchased the little alloy joiner?
Pics would make it crystal clear if you could buddy
