Air vent gauge and best boost gauge
asquith_4
Fr -260
Feb 15, 2012
41
Hi guys im wanting to fit a boost gauge to my fr tfsi, ive been looking at the tt air vent pod they do am i correct in saying it will fit the leon ?
Or could anyone suggest another pod to buy
One more question could anyone recommend an averaged priced boost gauge and fitting kit
Thanks very much
luke2702
Cupra K1
Aug 22, 2010
462
Bolton
Thanks very much
I have a pod on my Cupra but it covers the little triangle window and holds boost gauge. Not sure were it is from as was on car when got it. Will try and get pic tomorrow. It is possibly from Awesome as lot of the work was done there...
asquith_4
Fr -260
Feb 15, 2012
41
Yeah nice one mate! And will check them out and see what i can find! Really fancy the air vent pod thou :)
Adman77
Audre Est Facre
Feb 13, 2012
774
Hertfordshire
I have the same as Luke, from here
http://www.nomadracing.com/catalog/...d=493&osCsid=43485fc3b2375c8074dfa6c2f15912c2
along with this
http://www.ebay.co.uk/itm/AUTOGAUGE-52mm-SMOKED-FACE-TURBO-BOOST-GAUGE-PSI-/370722875636
matches the Cupra clocks well. However is hard to see in direct sunlight.
Fitted by Awesome but not sure how much as it was being done as part of the work I had done.
How do you find that approaching roundabouts and stuff with the already poor A pillar visibilty?
As I'm also looking for a mount just not sure where to put it. I like that gauge though, as you said, looks like it matches the clocks well
lc_allan
Northern Monkey
Sep 15, 2006
3,389
It honestly does not get in the way. It only covers the little triangle window and mine was tinted black anyway. That is one thing I've not thought about since it was fitted so mustn't be an issue :)
The only prob is direct sunlight. Not really a fault of the gauge as such as it illuminates as soon as the ignition is turned on. More the position of the sun through the glass. If you have lightly tinted front windows it may not be a problem. Looks good at night though.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
I'll take one tomorrow. The car is tucked away and steering lock is on over the wheel.
hubbly_bubbly
[center][img]http://i374.
Aug 18, 2008
399
Johannesburg, South Africa
You looking for something like this asquith?
http://www.seatcupra.net/forums/showthread.php?t=186450
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
I've got this setup waiting to be installed. It's quite a kit. The bezel for in the air vent is quite a piece.
Haven't gotten around to installing it...got cold. :)
shnazzle
Sep 9, 2011
3,480
Northumberland
where do you get this Vent pod from??? and also what else is needed to fit a boost gauge
Doesn't exist. The bezel has to be made. The rest is easy
- For petrol: a T-piece to tap into a boost line
- For diesel: a tap into the pipe that goes to the EGR
- a spare vent (SERE), not 100% necessary
- a gauge...duh. Mine's an omori stepper gauge with electronic sender.
Got my gear from CupraRob on here.
shnazzle
Sep 9, 2011
3,480
Northumberland
So shame to say I still haven't done it for my car and I still have the plates! :(
I tried about a year ago but I wasn't able to pry out the vent..
Get a cheap set of trim removal tools off eBay. Makes it all a lot easier. My vent popped out quite easy.
