Holdup's 05 LCR RR - Revo Stage 2, Quaife LSD to fit!
Holdup
314
27
Kent
Oh yea I'm on the list for that already thought it was something else for some reason.
The car is with AMD for an sfs tip and stage 1 map :p
Sat in Ikea restraint currently waiting for it to be ready. Had a phone call about 10 o clock cars been road tested and the egt sensor is throwing a fault but is ok for now
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Have you seen the Bromley Pageant thread mate? It's going to be good! :D Come along!
http://seatcupra.net/forums/showthread.php?t=371990
Good stuff on the tip and the map. You'll love the drive home. Stay safe in the snow! You may notice it'll be tough to get the power down with this weather!
Holdup
314
27
Kent
I've put my name down :p
Well I'm back from AMD I am so happy with the car
It is now producing 281.6bhp!
When I get a mo I will do better write up
Sent from my HTC One X+ using Tapatalk 2
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
:funk:
Nice one mate! Look forward to the write up.
Good work on getting your name down for Pageant too! We want these shows to be even better this year! :D
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
281 from just a map!?
what tourqe did you make?! u got a screenshot of the graph?!
281 is alot of power bet your glad you went to amd, r tech only make 280 with full saurst/filter/decat/badger5 tip/cold air intake/front mount.
so getting 281 with just a tip is awesome!! :worship: AMD King of remaps.
Holdup
314
27
Kent
Car is running cat back, cone filter, forge 008, sfs tip stage 1 map and always filled with v power.
Prior to map car was producing 237.4 hp with 226 lbft with map its now running 281.6 hp with 322.1 lbft
Holdup
314
27
Kent
As long as your happy with it mate that's all that matters. People will always hate.
I'm more than happy with everything AMD done for me, the car is just so much better to drive. I had a discussion with Shaun (sorry if I spelt your name wrong) at AMD about people hating
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Top result mate, great to hear your happy with the car. Shaun always has good views on the bad mouthing that goes about all the time
matt88 lcr
450
my car had amd stage 2 map made 296hp and about same torque then on ***** rollers it mad 273hp and 290ish torque with amd map now got ***** map as was having hugh boost spikes of 30psi on amd map. But now bosts to 21psi and made 280hp and 310 torque and pulls alot smoother and right toredline on ***** map unlike before power droped off at 5500rpm
matt
684
Slough
my car had amd stage 2 map made 296hp and about same torque then on ***** rollers it mad 273hp and 290ish torque with amd map now got ***** map as was having hugh boost spikes of 30psi on amd map now bosts to 21psi and made 280hp and 310 torque and pulls alot smoother and right toredline unlike before power droped off at 5500rpm
matt
He's happy with it. Leave it at that.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
matt
Well mine doesn't go near 30psi on AmD stage 2 so must just be your car that did that.
Mine holds 23psi and is very smooth.
As Charlie says, he's happy with it and that is what matters here :)
matt88 lcr
450
Yea mine was fine most time but had odd spike and it kept dropin off . Not sayin all amd maps do wht mine did. And just coz he got 280hp on amd rollers dont mean it same as 280hp on r t ech rollers ever rollin road different
Matt
matt88 lcr
450
Wasnt avin ago just wanted to state tht him getin 280hp withamd is same as 280 hp with ***** roller as mine had a hugh differance beteew the two sets of rollers
Matt
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
30psi is pretty much 2 bar which is HIGH. Only time mine hit this is when my N75 died.
Replaced it and never been above 1.6 bar since.
Feb 14, 2012
684
Slough
Mine made 275bhp on AMD rollers and just over 260bhp on another on just a stage 1 map. Tbh I'm not bothered because it's "dyno lottery" but my first RR can be the bench mark for me as I'm now ready for stage 2 after I fit my FMIC. It will just be used as a comparison for me so I can see how much MY car has progressed.
Feb 14, 2012
684
Slough
And just for the record I think AMD are a cracking bunch of lads and the customer service is great, even though they may be a tad more pricey than other tuners, I know if I have any issues it will be sorted without a problem.
D.K
LCR 225
Oct 24, 2007
6,408
se london
I think too many people get to hung up on Dyno figures.
My car has only ever been on 1 set of rollers and I use the firgues from those sessions purely to see what increase I get when new parts are fitted.
There are far too many variables to take into account to say that one set of rollers is more accurate than another.
As has already been said so long as the owner is happy and the car drives well then happy days :D
