think he means the upper strut brace as lcr has the lower one same as tt s3 as standard
matt
Drilled mine myself just takes time to line it up correctly and the bonnet strut also blocks 1 of the holes up....
Mk1 S3 strut brace.....
Sent from my iPad using Tapatalk HD
I got a mk1 tt to go on mine,need a notch cut where bonnet strut is apparantly
Ah sweet alright mate cheers. Where did you get the bolts from? Are they nut and bolted or do you need to tap threads in once drilled? Im gonna get its powdercoated anyway so cutting a notch wont be a problem.
Ah my bad.
But eh...have you used the search function? Step by step posted below
Click: http://www.seatcupra.net/forums/showpost.php?p=349640&postcount=23
Source: http://www.seatcupra.net/forums/showthread.php?t=33814&page=2
No prob, good luck
Alternative: Wiechers (cheaper). Mate of mine fitted one in his Leon V6
Thats pretty cheap indeed![]()
Maybe plastidip it?
Its vulcanic rubber in spray form. Just spray it on, if you want to remove it, just pull it off (see youtube for examples)
