LJA
281
Derbyshire
Evening,
I'd like to get a list together of what VagCom can and cant do.
I had a quick search and couldn't see anything, so I thought it would be a good idea
As an example it can turn off the corning function but cant activate needle sweep
I think if we could get a nice organised list together, a few of us may be able to activate options we never thought we could etc.
If you could maybe include how to do it aswell!
Please contribute.
The document I have shows the following available for the 6J ibiza
2 Central doorlocks
2.1 Anti carjack
2.2 Auto unlock when removing the key from the ignition
2.3 Automatic lock above 15km/h
2.4 Re-lock after 30 seconds
2.5 Short car horn honk at lock/unlock
3 Car lighting
3.1 Leaving home
3.2 Lamp Diagnostics
3.3 Disable interior light at key removal
3.4 Emergency Flashing Active
3.5 Comfort Turn Signals (CTS)
3.6 Cornering lights (on cars with halogen headlights)
3.7 Coming Home through fog lights or low beam
3.8 Parking lights 3.9 Cornering lights when blinker is on
3.10 Disable front fog lights
3.11 Assistent Driving Light active (ADL)
3.12 Daytime Running Lights (DRL)
3.13 Light activation threshold
3.14 Light Sensor Correction
3.15 Highway light function
4 Wipers/Rain sensor
4.1 Rain sensor
4.2 Rear wiper when gear put in reverse
4.3 Tear wiping (front)
4.4 Rain close
4.5 Rain sensor correction
4.6 Front Wiper Service Mode/Position
5 Outside mirrors/rear window heating
5.1 Heated outside mirrors
6 Telephone & Bluetooth
6.1 Language speech recognition
6.2 Voice operation
6.3 Audio parameter set
6.4 Cooperative mute switch
6.5 Bluetooth audio (A2DP)
6.6 Bluetooth antenna diagnostic
6.7 Bluetooth acknowledgement signal
7 Miscellaneous
7.1 Car horn disabled when no key in the ignition
7.2 Cruise Control
7.3 Seat belt warning
7.4 Seat belt warning tone
7.5 Language dashboard and Bluetooth (car kit)
7.6 Correction fuel consumption
7.7 Change display fuel consumption to km/l
7.8 Parking aid activation activation tone (PDC)
7.9 PDC pitch
7.10 Towbar adjustments
7.11 Staging or needle sweep (not available on the 6J )
7.12 Radio Driving School Function
7.13 Radio Development Test Mode
Perfect. Eactly what I wanted. Can these be turned on no matter what. i.e Coming home function if you dont have the required pack? (Tech pack?)
Some functions are accessory dependant.
Anything to do with Auto wipers and lights require the sensors to be fitted
Light level adjuster is only for xenon option
Tow bar functions require the tow bar
Reverse sensor beep requires the reverse sensor pack.
I also noticed that the XDS ( electronic limited slip diff ) adjustment is not on the list.
Best bet is to do a full car scan when you get VCDS and a cable.
Then the VCDS knows what is possible on your car.
Does the document you have state how to do this ? I.e how to turn lock on over 15kph. I hear a noise but I tried to open my car and it hadn't locked ?
Yes - its a pdf documment but the site wont let me post it up.
Send me your e-mail addy in a PM and I will send it to you
EDIT - the locks only work from outside on the drivers door over 15kph and they unlock when you remove the key
What are all these cheap cables on eBay at £10?
Never tried one BUT :
You will need a hex+can type cable to work with the 6J ibiza due to the CANBUS system and if it doesn't work there will be no support from rosstech.
Many of the cheap cables come with an unofficial copy of the rosstech lite software and have limited capability.
