N/A Cams
Any one know the best N/A 20v cams are to go in our 1.8ts?
Ive read a bit on hear and Jamesjudd was gunna use AGN cams both inlet and exhaust.
But also read ADR cams are the same size as BAM ones (guessing this is the largeport head)
Anyone actually run any etc or have more info
Tucker157
1,065
Falkirk/Central Scotland
AGN cams have the highest lift i found out.
And NRM90 has james engine so be interesting to if he plans to run both cams.
Be nice for someone to just clear this up.
I've heard of just using the inlet cam.. I'm sure it was on VWvortex.
ADR I believe is both large and small port.. It changed at somepoint for unknown reasons. Earlier ones are large, later ones are small.
Sent from my iPad using Tapatalk HD
Prebs
662
Norway, Bergen
Will be following this
I can comfirm that early ADR also is largeport as I got a hold of one for a rebuild sometime in the future
inlet:
058109021 = ADR und AFY 8,78mm, 210°, 4° n.OT
058109021.B = APX, ANB, AEB,APU, AJL, AGU, AQA, ARZ, AJQ, APP, APY, AUL 7,67mm, 190°, 18° n.OT
058109021.K = ADR, APT, ARG, AVV 8,41mm, 202°, 16° n.OT
058109021.M = AWT, AUM, ARX, ARY, AUQ, AMK, BAM, AUL, APP 7,67mm, 190°, 18° n.OT
058109021.F = AGN, APG 8,41mm, 202°, 18° n. OT
058109021.E = AWB 8,6mm, 207°, 9° n.OT
058109021.D = ADR, AGN 8,41mm, 202°, 12° n. OT
exhaust:
058109022.B = AQA, ARZ, AJQ, APP, APY, AEB, APU, ANB, AJL, AWT, AGU, AUM, ARX, ARY, AUQ, AMK, BAM 9,3mm, 210°, 10° v.OT
058109022.C = ADR, AFY, APT, ARG, AVV 10,25mm, 210°, 8° v.OT
058109022.D = AGN, APG 10,4mm, 210°, 8° v.OT__________________
BIG4244
51
Dartford kent
I have a forged AYP with ko4, relentless mani 3" down pipe, 3"tip WMI etc I've recently purchased a pair of ADR cams and will be doing a back to back comparison at work, the car will be run on the dyno twice with AYP cams then changing them on the dyno and running another 2 times I won't post peak figures to save all the dyno crapmthat goes on just gains or losses and a PDF of the graph hopefully do it early next week
Chambers... Great info!
have you got AYP and AQX as a comparison?
Haha i found it in jamesjudds thread and stole it haha
Thought it would be useful here to everyone :)
AGN have biggest lift by the looks of things probs have to buy a hole engine to buy some tho lol
Edit: May ADR inlet and AGN exhaust cams would be a good combo?!
Big-Pete
Always on the Limit
Aug 8, 2010
2,969
AGN Cams is what mine has, theres **** all bottom end. but then im running silly boost sooooo yeah. it could be down to mapping aswell.
Big-Pete
Always on the Limit
Aug 8, 2010
2,969
Yeah mines over bore 1850cc Wossner pistons and ina rods as far as I'm aware
