Right heres a few pics of the install of this battery up front.
You will need:
1. 2 motorbike battery leads, as thick as possible, think these are 10mm
2. Shrink wrap/blick insulation tape
3. Hacksaw, drill, screwdriver, socket set
This is optional but i wanted to make space. Cut the battery tray so its 2/3 of size. Gives room for mounting battery and also space as a platform to fit something else if needed. I went for an isolator switch as the battery will be dead after 8 days of non starting unless its isolated and will then last for weeks. Not a
problem for most people since i would imagine they use their car at least once a week, if i go away with the army on exercise, it could be anywhere from 2 -6 weeks.
I then re installed the tray, drilled slots for the heavy duty zipties, mounted the battery as far right as it could go, tied it down.
I then cut off the oem terminal on the + side and used the motorbike lead to connect it to the battery. It screws down on the race battery terminal one side and i used shrink wrap to join the end of the oem battery lead to the other side.
The - side, i unscrewed where the oem lead is grounded to the chassis and screwed in the motorbike lead instead, then the other side was screwed into thebattery.
If you look at the oem "wire box" is so to speak, i have removed the bit of plastic underneath which fitted around the orignial batter. It helps it to fit, just prize it off with a screwdriver.
If you look at the above pic, the green mount is for a isolator switch which hasnt been done yet, I will cut the negative terminal in the middle and attatch to the switch. At the moment i have them just connected with insulation wrap so i can easily disconnect them when required.
Pick of where the battery is grounded, i have taken the nut off but you can still see it
Apologies for poor pics, were taken with my phone
