Cos
20VT, bitches!
Aug 27, 2010
473
Brighton
Right, I'm in need of help as I'm at my wits end with this stupid car.
I'm trying to change the suspension on my Ibiza, and I've managed to remove the RHS strut and spring assembly, but the top mount is stuck. I removed one bolt, but the other two just turn without coming out. I've tried griping them from underneath with mole grips, but they just come off. I've tried drilling the top off, but I only get about .5mm in, and I've tried smacking the **** out of it with a hammer, no joy.
Does anyone have any suggestions about how I could get them out? I don't have a welder nor an angle grinder and a hacksaw can't reach the bolts.
Pics for reference:
Top
View from inside the wheel arch
And for reference
Thanks in advance <3
Trouble is I can't see me using it again so one 1 mins work it's not really worth it :/
for a tenner id go buy one...got to be worth it..
use it once..clean it up and take it back ..lol
1) hand back your man pass as you enter womanhood
2) how much is your car costing you to not have on the road while you wait for the bolts to fall off?
I had a couple of stuck ones first time I did mysuspension. I hit them with the grinder.
As for not needing a grinder again - how do you trim your toenails? :lol:
I found a good quality drill bit sorted mine out!
Same here. I had one that I had to drill out and it drilled out no problem at all.
It looks like you have used a too small a drill bit. You need one about the same size as the thread or just slightly smaller then hitting it with a hammer should knock the shaft out.
Ok a lot of swearing a drilling later (and splashing out on some titanium tipped drill bits), here we are:
Thanks for the suggestions
