EGR Delete, yes or no?
Mujnu
Do 1.4 petrol ibiza 03 plates have dpfe sensor? i was told only diesel cars have them? And also if the car does not have a dpfe sensor would changing the egr vavle get rid of the p0402 code?
Mujnu
DPF and DPFE are two different things. You don't have DPF though. Fitting a new EGR may well get rid of your problem though.
Whats the difference between the two if you dont mind me asking? And oh great thanks for that, by any chance could bad coils cause that code to pop up? And whats so good about a pierburg egr valve and a standard one?
Sorry about the tonnes of questions i like to know about what i want doing before getting it done ;)
NelsonTDI
Hi all New here ! joined as i have just got a seat ibiza tdi 100 2006 run diagnostics on the car and have a problem with my EGR valve (clogged up) and as a result my engine management light has come on, My question is if i use the procedure on this thread (vagcom software and cable) will this then turn the engine management light off ?
