Turbo revs Diverter valve
Azza_
526
South Shields
can hand on heart say the bosch one 710n is unreal for what it is, my car seems to come on boost better than my baileys, which is now going to have to be sent away for refurbing!
MrC
52
Baileys should only be enjoyed from a glass. Add ice if you like....
B47t0n
162
Im just thinking ahead as in the future ill be getting remapped, ive read the bosh is no good once mapped ?
Azza_
526
South Shields
the dv30 is LOUD when dumping off even on my unmapped car, but you cant service them yourself, if it leaks you have to send it back to bailey who will refurb it for 36quid supposedly they check all the body and piston for clearance and if any parts need replacing (including body) its all in the 36quid price
fran1987
213
hull
Azza did you have to do anything else other than replace your standard one with the baileys? I asked the question on here a few weeks ago which dv is best to get the sound when dumping and I was told if I replaced it with a different dv that my system would go into panic and not have enough air? I'm looking for the noise when dumping( changing gear) will I get this from a baileys?
Azza_
526
South Shields
an aftermarket dv will not make your car go into "panic" / limp mode, so long as you stay with a recirculating valve aka the dv30, if you go for an atmospheric dv aka forge split r then these cars hate that as the air it dumps is air the engine expects to see,
The only thing i done was replace my standard dv with the baileys dv30 and also a nice open cone filter
altho since my dv30 leaks im back to the standard bosch 710n altho not as loud as the baileys it is definitely more audible due the the open cone jetex filter
