pcd on new leon is 5x112 and et50 mate.
The PCD is 5 x 112 and the centre bore is 57.1 but the OEM ET is not 50.
The OEM 6.5 x 16" wheels on the Mk 3 SE have an ET46. The OEM Mk 2 used ET50.
Other sizes have different ET's which are cast/stamped into the rear of the wheel.
Mk 3 wheels have a different ET to Mk 2 wheels but the ET's are common with other new models using the MQB platform.
Took me several weeks to get a set of wheels for my winter tyres. Loads of Mk 2 wheels but Mk 3 are thin on the ground.
You can use a wheel with different ET (AKA offset) by putting a bushing/washer (not sure about the term in English).
Yes you need to make sure you get the correct et for your car, not having the right et for your car will cause all sorts of issues
Do a search on the internet, there are plenty of calculators that will allow you to put in the car you have the size wheels you want to fit to it and will give you the tyre profile etc etc that you need
Its well worth taking the time to research a little about what things like et mean and how to keep the same rolling radius correct etc
It gets expensive to buy wheels and tyres to then find they don't fit so its worth a bit of research
Well the wheels I want are the Audi 5 spoke ones that are like a graphite colour, you may have seen them. In either 17" or 18", abit undecided on size as I don't know how hard the ride would be.
I think it's called a spigot ring if that's what you're talking about.
anyone know whether mk2 leon 16" 5 spoke (or jetta 16" 5 spoke, golf mk7 16" 5 spoke) will fit as offset? It seems to me that my standart 16" SE turbine wheels (10 spoke angled) can get away with a little more offset.
I have them on my audi a3
Its a 12 plate so I will check the et for you.
If you buy the very latest ones you will probably be fine as They are all built around the MQB platform as Skidpan stated above so should be able to fit
Mine are 17s and I find the ride just about right, although the 18s look slightly nicer
But the bigger the wheel size the thinner the sidewall and the ride comfort can suffer so its always down to personal preference and the reason I had 17s not 18s
When I was looking to buy wheels for my winter tyres I quickly discovered that for 6.5 x 16 the Mk2 Leon and its brethren used a ET 50 whereas the Mk3 MQB cars use ET 46.
I agree that there is some clearance between the wheel/tyre and suspension but considering that the designers know a thing or two there must be a good reason for this change. I know its only 4mm but the Mk2 wheels will put the wheel/tyre closer to the strut etc. In truth it should not be an issue, seen much less clearance on many OEM set ups but if you had an accident your insurers may try and use it as a get out of jail free card. If you are up front with them they may agree to the change.
At present there appears to be relatively few companies selling aftermarket wheels that match the OEM specification for the new cars whereas there are loads of wheels (OEM and aftermarket) for the earlier cars.
The 18 inch performance wheels as fitted to the FR's are 7.5 x 18, the PCD is 5 x 112 and the ET is 51. I took note of this when I had the wheels off to paint the brake calipers. I hope this helps.
@Skidpan - may I ask please, where did you end up getting your winter wheels and tyres from in the end? And what did you end up with? (16s? 17?s 18s?).
