Retrofit cruise control
ahadmehmood
32
Hi I was wondering if somebody can help. I have tried fitting cruise control to my car however I keep getting fault E45 implausible signal defective stalk. I already have a a wire running from pin 13 to the central electrics and the cruise has been coded to the engine and central electrics correctly however this error still keeps coming back. I have tried two different stalks this one being brand new that I purchased from vw teeside. My steering wheel control module is compatible 1K0953549CH.
Does anyone know where am going wrong or what I can do to rectify this from what I know it's supposed be pretty straight forward.
On vcds switch monitoring it picks up when I flick the on and off switch but the accelerate and de accelarate there is no response.
I have taken everything apart 3 times now and checked the coding numerous times not sure what is happening
Ben750
361
Pontefract, West Yorks.
On my pre-fl Cupra the green light doesn't come on on the dash at all and the CC works fine. I'm told it depends on the age of the car.
If you know the stalk is good, I'd check the wiring.
ahadmehmood
32
Yea I understand stand that on earlier models there was no light but mine still does not work. The wire from pin 13 to was already there
Rob66
1,629
97
UK
My 05 TFSi Sport had Cruise and no green light either - worked fine though.
ahadmehmood
32
This is my VCDS LOG
Thursday,14,November,2013,19:01:49:51843
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: VSSZZZ1PZ6R086566 License Plate:
Mileage: 141030km-87631mi Repair Order: MO's 2006 Seat Leon 2.0TDI
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56
VIN: VSSZZZ1PZ6R086566 Mileage: 141030km/87631miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LL HW: 03G 906 021 LL
Component: R4 2,0L EDC G000SG 9185
Revision: --H03--- Serial number: SEZ7Z0F3473219
Coding: 0050072
Shop #: WSC 12345 123 45678
VCID: 74E187231771ACBE80B-8021
2 Faults Found:
001384 - Cruise Control Switch (E45)
P0568 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141037 km
Time Indication: 0
Date: 2000.00.00
Time: 18:48:31
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141037 km
Time Indication: 0
Date: 2000.00.00
Time: 18:48:31
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11001100
Bin. Bits: 00000000
(no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0000641
Shop #: WSC 06441 785 00200
VCID: 3F8B180F6EB73FE6AD9-806A
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 5P0 820 047 M HW: 5P0 820 047 M
Component: Climatic PQ35 014 0606
Revision: 00014014 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 377B702F468707A6659-8062
2 Faults Found:
01296 - Sensor for Vent Temperature; Center (G191)
007 - Short to Ground
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003969246
Coding: A1880F3F00041000001D00000000000000007F075C
Shop #: WSC 00008 210 45725
VCID: 2B535C5F8ACFB346111-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 00008
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 6
Mileage: 141037 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 6
Mileage: 141037 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.95 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R4 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PDCNUPD
Coding: 0021044
Shop #: WSC 04941 785 00200
VCID: 2F6B484FBED7CF663D9-807A
Subsystem 1 - Serial number: 6332MSME0E405F49
Subsystem 2 - Serial number: 6342MSME0E340A72
Subsystem 3 - Serial number: 6351HTS64IKMM563
Subsystem 4 - Serial number: 6361HTS63IKAIAT2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CH HW: 1K0 953 549 CH
Component: J0527 056 0111
Coding: 0000534
Shop #: WSC 12345 123 12345
VCID: 7AFDA91B3515DACEDA7-802F
Subsystem 1 - Part No: 1P0 959 538 B
Component: E221__MFL-TAP H01 0100
Coding: 00000226
Shop #: WSC 00000
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 941 A
Component: KOMBIINSTRUMENT VO3 0724
Coding: 0002401
Shop #: WSC 00046 476 88215
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010630681B3
Coding: 7D0F0348072203
VCID: 2A5D595B8535AA4EEA7-807F
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 62
Reset counter: 6
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:36
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0724
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 C HW: 1T0 035 680 B
Component: RNS-MID H11 1300
Revision: AB001001 Serial number: VWZ6Z7J8273164
Coding: 04000400040000120020
Shop #: WSC 00020 790 12345
VCID: 2E55554B79DDC66E36F-807B
2 Faults Found:
03138 - Input AUX IN
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:51
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:52
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2352
Coding: 0000688
VCID: 36657D2B418DFEAE7EF-8063
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3461472357F1ECBE40B-8061
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC09000505485B863004CC
VCID: 79FFB6173013D1D6D3D-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE No Answer
2 Faults Found:
01135 - Interior Monitoring Sensors
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000688
Address 55: Xenon Range
Cannot be reached
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:51
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 140726 km
Time Indication: 0
Date: 2000.00.00
Time: 16:27:52
End ---------------------------------------------------------------------
J400uk
1,978
London, UK
Mine has a light for cruise. When I had it fitted the first stalk we used (from a 06 TFSI Sport) didn't work and nothing happened when you turned it on and pressed the buttons. Replaced with a brand new stalk and it worked. I've been told the stalks are quite unreliable and its not unheard of for them to fail.
