Passenger Door Unlock problems
Masterkm
My Leon 'Alyssa'
Jul 11, 2011
2,860
Halesowen, West Mids
Today my Passenger Front door lock was playing up, I try to unlock all doors and the front passenger door doesnt sometimes unlock and will only open on inside. Did it a couple tries and it started working again after a VAGCOM scan.
Is something on its way out and requiring repair? Here is my VAGCOM scan and its showing as intermittent so sounds like it could either be weather/slamming related.
Any ideas?
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1124
Revision: 11006001 Serial number: 00000011968707
Coding: 0000688
Shop #: WSC 06441 785 00200
VCID: 3C7C839A7F70863
2 Faults Found
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 107
Mileage: 141068 km
Time Indication: 0
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 67
Mileage: 141068 km
Time Indication: 0
si289
I'm having the exact same issue on my '57 Leon FR. I can open the door fine from the internal handle but it frequently doesn't not unlock via the keyfob or the internal unlock button. Seems to be more frequent on warm days.
Did you solve your problem?
- Simon
joestella28
63
I'm having the same issue, it seems to constantly try to lock the front passenger door whenever I go over the auto door lock speed (i.e. if I drop below that speed and then go back over).
Any thoughts?
Joe
si289
Any thoughts?
Joe
I had to replace the door locking module in the end, haven't had an issue since! Have you vagcom'd it?
Si
joestella28
63
No not yet, that's the next step. Did you replace the module yourself? How much did it cost if you don't mind me asking?
Thanks,
Joe
si289
Me and a friend (mainly the friend if I'm honest, lol) replaced it in a morning. Cost me £45 used. Was quoted £145 new. Would definitely recommend getting a vagcom on it and make sure that the errors are the same.
Si
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
Si
hi mate are you talking about the actual central locking motor attached to the door handle or module as part of the window motor?
si289
Hey mate,
It was the actual motor which connects to the door handle.
Cheers,
Si
Masterkm
My Leon 'Alyssa'
Jul 11, 2011
2,860
Faults came up again and problem is back, think its defo due to the weather and after clearing the code it ccame back, but it worked about 3 times and then stays locked. Can only open from the inner door handle.
Whats the cost of this fix guys?
joestella28
63
I'm having pretty muvh the same problem with mine but now with the added bonus of the alarm randomly going off! Starting to go a little mad.
Does anyone know where I can buy a replacement front passenger module from? I can find them for mk1 leons but not mk2's?
jonovan82
this happened to me but the drivers door(door stopped locking, alarm going off, central locking stopped working)
I am pretty sure but may be wrong that its a seat only supplied part that needs to be coded with vag com it cost me £230 ish for the part and cost £430ish fitted by a indy garage... hope this helps
Geordie2001
73
My rear passenger door wouldn't open at the weekend. Its now ok..
no doubt it'll happen again.
