So I got in the car thos morning on my normal drive to work and was greeted with a 'Check Coolant' warning. It was cold and dark so I thought I would check it when getting to work.
Now the coolant was closer to min than max when I first took delivery of the car but look at this!
Isn't that exactly what I said in the 3rd sentence. "A simple pressure test at the dealer should discover any leak".
Guys, any updates? I have my car (1.8TSI) for almost 4 months now and it looks that the coolant level droped, but not as much as yours.
Seat will do a pressure test for you free of charge and do a software update while your car is with them (Just an update on the bluetooth software).
Mine is going in tomorrow to have the coolant looked at and also the faulty indicator stalk which went in the end of October as it was not cancelling after turning the wheel. Problem has returned. Will let you know when I have the car back.
Thought I'd resurrect this thread. I noticed the coolant level of my 1.8 TSI was just below the minimum line back in November last year. The dealer tested the system, found nothing wrong with it, and topped it up to just below the max line (when cold). Now, 2.5 months on, it's dropped by about 1cm. Any suggestions as to whether I should just top it up or does it warrant another (!) trip to the dealer?
