Is the 0.63 a ratio of the inducer to the exducer size? The closer the value to 1 then it needs or is able to extract more energy from the waste gases at higher rpm and make more big end power. Is that the correct way of it?
Very nice neat job. Would the engine top cover usually sit at that angle? Is there enough clearance once the bonnet goes on?
Getting near now mate, when is she back on the road. March![]()
Phil LOL, it was only last week I finally fitted my Feel Charge pipe only been on the shelf for 7 years and I have to say its great...... I gained 3g/sec in airmass flow.Awesome work. Really awesome.
Just one thing - the stock charge pipe has a little spigot/stub underneath that sits in one of the grooves on the bracket. I'm 95% positive that leaving this off some custom charge pipes I did a while back is what helped them to blow the silicon off the charge pipe, because the whole charge pipe moves north west in the mountings.
Sorry if it's a bit late, just thought I'd mention it.
Edit: Mind you, the ends of ours weren't swaged, but I would still think about it.
