leon cupra - winter protection
ibizaboi
392
Sudbury
Your car looks awsome!! Looking forward to seeing it on air!! I dont sopose you know if that floor would fit the mk1??
Sent from my GT-I9195 using Tapatalk
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
Visit site
It tends to be inbeween coilover and oem ride quality.
Just a small update. I've still not got the pressure switch so I'm stuck.
Today I quickly fit the blanks to the tank asw ell as the outlet and as a make shift fit a gauge on there where the switch goes.
I wanted to leak test the tank. So far so good. Pressure has held at 100psi for the last three hours. I'll see what it's like in the morning.
I've also Ordered an accuair speed switch as a controller instead of the switch box I made. Purely as I had birthday and Christmas money haha.
Jacob8877
7
Hey Jake
Can you help me with a little something, I'm about to renovate my own Cupra 1p 2007.
I stand missing a part number on the right tail light from a faceliffted Cupra (2009-2013). You have them on, so I thought if you wanted to check it for me?
Jacob8877
7
Which one fella. The tailgate lights are a different shape and you have to change the tailgate.
I changed the tailgate.
must use the part number on the entire right rear light to a facelift.
thanks mate :)
jake
Feb 2, 2003
2,666
rochdale
Visit site
30 seconds search
Passenger outer light 1P0945111G
Passenger inner light 1P0945107P
Driver outer light 1P0945112G
Driver inner light 1P0945108P
You will need resistors as they can't be coded. These are the led light part numbers
Jacob8877
7
30 seconds search
Do you have part numbers on the original, not the LED lights?
waggyy
31
bugbrooke, northampton
Hi Jake,
Really like what your doing to your car, looks like quality workmanship ;0) Can you tell me what model of car the boot organiser came out of please.
Cheers Paul.
Jacob8877
7
Just get the reg off a fl car then ring the dealers.
The problem is that my Cupra is Danish and to Danish number plates on it.
Should only use the part number on the right tail light from a facelift right hand drive.
Hope you understand and want to check up on it for me. :)
