Have patience, its not the easiest of things to fit especially trying to fit oil and coolant banjos with new washers
Also remove coolant return from block then remove from turbo as you cant access this banjo whilst turbo is in situ
Reactions: adambudders
you will have to get wet im afraid to undo coolant return to the block and oil drain from turbo.
Also the turbo has a support bracket that bolts to the block and a couple of the downpipe nuts are accessible from underneath
Aww man!
Thats what I was afraid of!
Do you know if its possible to pull the turbo and downpipe upwards and out of the car together once the manis off?
Can you tell I really don't wanna be under there?!! :help:
Youll need to split downpipe from turbo to remove, plus you wont be able to move turbo until you've undo the support bracket.
You will need to get under it im afraid
Interested to hear how you get on with this. I was just about to post up asking the same. I am changing my turbo for the same recon unit. What seals/gaskets/bolts will I require to replace with new and what can I reuse?
Its not as difficult as its made out to be...Patience is the key and a fair bit of time on your back..Replaced mine, took a day but did other bits aswell. Took turbo out above gearbox by airbox.
