mauinho
Hey, just got myself a Leon (Mk2) 1P and Im quite happy with it got quite a lot of car for my cash :D
Saying that I've got a little annoying issue I cant seem to figure it out maybe you guys can help a "noob" like me.
The remote fob locks and unlock the car perfectly, but once key is in ignition and I start driving, the car locks it self after a certain speed as it should, now if I want to stop and let a passenger in (picking up kids, wife ,etc.) their doors or the boot wont unlock if I press the unlock button near the gear stick, the only way to unlock things is either me manually let them in, or remove key from ignition and double press the fob unlock button, very annoying indeed , is this working as intended? I can use the lock interior button to lock the doors (I've tested it) and it lights orange but the unlock side of the same button doesn't seem to do anything at all... I can live with that minor issue but I thought I'd ask the proper experts to see if there's an issue and/or solution!
Thanks in advance.[B)]
It certainly should unlock the car so there is a definite fault.
Could be a duff switch.
Welcome to the forums :wave:
Thankx for the quick reply.
I was hopeful it might have been me doing something I wasn't aware of like setting some sort of "safe" system ... oh well I'll have to get it checked once it goes to it's service.
Could be something very simple, but in the meantime it's a good excuse not to pick up any passengers :p
my first call would be the switch... try to borrow one, or if you are handy with a multimeter, test it.
could be as simple as the connector not seated...
Sent using Tapatalk from my ZX81
I've also just brought a Leon FR TDI but I am unable to lock or unlock my doors from the inside... Is it easy to open up to see if it is conected? I dont want to break anything :blink:
ok managed to get a friend to do a scan on my Leon of course I have no idea what any of it means but heres the faults:
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No: 1P0 920 940 B
Component: IMMO VO3 0518
Shop #: WSC 61019 476 02565
VCID: 2B55E1278AF0EB46111-807E
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2452
Coding: 0000688
Shop #: WSC 06441 785 00200
VCID: 377DCD5746B85FA6659-8062
1 Fault Found:
00100 - Drivers Interior Locking Button (E308)
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC090005054C5F863004CC
VCID: 79F90B6F302C89D6D3D-802C
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
not sure its the interiors lock/unlock buttons faults anymore... also is it safe to clear the faults?
Looks like the one relating to 'drivers interior locking button' is your issue!
The fault code related to interior monitoring sensors comes on all cars, nothing you can do about it!
It's the locking switch in the centre console. Does yours have a key and a car with an open door on it? Or a locked and unlocked pad lock? If it's the first one they were prone to failure and were superseded by the latter as a replacement.
It was the first, Thanks. I am going to order a new one for the weekend. Are they easy to replace?
Hi mine is doin exactly the same, did u fix it and what did u have to do please
Lol i feel like a numpty asking!
So no messing about with the driver side lock or anything? Just changing the switch did the trick?
Did u get the part from seat? Or can u tell me where u get it from ive checked ebay no luck
Thank you
TPS or seat. You need to remove the centre trim. It can be pulled up with a pick or similar.
Its ok found the part number which is 5P0962125A for anyone googling this. I fixed the plastic dome button though by taking it apart and glueing a circul;ar piece of tinfoil to the plastic dome plunger :)
