6th gear problem. HELP?!?!?!?!?
CHRI55
Yes its been Tango'd
Oct 15, 2006
255
Norfolk
Hi all having a bit of a problem over the weekend and was wondering if anyone knows or has had the same problem. Basically I can change into any gear: 1st, 2nd, 3rd, 4th, 5th and Reverse with no problem, no grinding or any other noises or jolts.
But when it comes to 6th the stick gets stopped, it’s like there is no 6th gear I have to then push the stick back into 5th and quickly down into 6th to get into gear properly. Is this linkage related????? Like I said the gearbox feels fine it literally feels like I can’t select 6th like someone has removed it.
:( Hope someone can help. Thanks
boggle
117
KENT
from experiance check the nut on the selector shaft and grease the slider on the linkage
do a google for O2Q gearbox - 7th result down is the vw workshop manual :)
