AUQ inlet breather split!
Garnaby
52
Blackpool
I apologise first I've looked at diagrams but nothing seems right! One of hen inlet manifold pipes has split! On my AUQ LC if you take off the metal pcv plate at the front and look under the manifold there are two pipes close together the one on the right has split can someone tell me if this is correct pipe I need?
eBay item number 160869104572
Garnaby
52
Blackpool
Think so it's only about 12mm diameter and is about 30cm long and looks like an S
useyourname
322
In a shed
Is the metal plate underneath the engine? Sorry to be a tard but I've got a vacuum leak and need to check this too.
