Ok chaps how do i know what part i need for fuel n pollen filter based off these pics.
Pollen filter is the 1KO 819 644 B and you will need the oil filter to see that. I presume the code on the code is the part number for the housing and not the filter
Rob, going by the pictures it looks the same as mine. I will pop out at lunch and see if my housing for the fuel filter is the same code, as the fuel filter was the correct one for me.
nice one mate appreciate that.
keep searching google with the numbers for that filter and the pollen filter and cant see any that match.........
Rob, checked my housing and its the same 3C0 127 400 C. The filter i linked to, should be the correct one unless someone else here says otherwise.
did you fit yours last night?
putting my detials in on the site gave me 3 different sizes, but if yours fits that housing then should be ok.
Fits. Even double checked with the one i was taking out. The rubber o-ring that it came with is the correct size as i haven't had any issues with diesel going past the o-ring like last time.
be interested to know which one you got and the number on the old one you took out.
had mine out last night to see how it looked. needs a change lol
Changed from elephant to Greenlight. Elephant had always been spot on but now the car has a few more mods, it was time to look for a specialist insurer
Greenlight beat brentacre by £120
Also, went to put fuel in the car and there was no V power, so had to change to my 95 ron map and stick a tenner in :(
Greenlight rules!! They've always had the best quote and service for us. 3 Leons insured with them so far. Weird that some people just can't get a good quote through them, but most do
1st world problems...
I have been to fill up at Shell twice recently and they have had no V-Power. First time I was too low so put in a tenner like you. Second time I had enough so just went back a few days later. Is there some sort of shortage?
