Hi guys i have a 1.6 ibiza tdi cr , and recently the air con has just stopped , tried to regas but made no difference , no leaks in the system either , also i cant hear the pump kicking in like before . Also looking at the pump pulley the little torx bolt seems to be sticking out slightly is this normal? This does not tighten up at all , also the clutch on the pump pulley does not turn when air con is activated the whole pulley turns constantly with aircon off or on ?
Anyone have any ideas ? Pressure switch or pump broken ? Its 2009 53,000 miles
