im getting it quited cheap under 250 so cant complain if i see 320-330 for now with good torqe that will be good...also will i need to upgrade diff? and whats the best clutch and fly?
I dont think you would see more then 310-315bhp to be honest. Clutch wise im running the Jabbasport sinlge mass flywheel and paddle clutch, cant complain at all :)
IHI TD05 16/18/20G will also fit.
Nice options available for 400+hp and quick spool.....
Compared (from left to right)
K03-052 - k04-064 (TFSI) - TD05 20G (old cast style compressor and 12 blade turbine)
About same size as Audi TTRS 5cyl. K16...
Same size TD05 20G in standard compared with Billet wheel option and 9blade quick spool option:
Unconventional "underslung" style jabba sports manifold......
So if you are fine with 350hp, you will normally be good with the slightly smaller 18G compressor and have even faster spool.....
Where can I get a quick spool 18g from? When will boost kick in?
anymore info on this will be great as my k03s is starting to get smokey
where can I get a manifold gasket from or will a standard new one fit? iAs for turbo m gonna go with a ihi vf35 for now just picked one up for 180
Manifold is from jabbasport (If you are lucky to receive a reply, I did not....)
Turbos can be had from Kinugawa:
shopping.kinugawaturbo.com
http://shopping.kinugawaturbo.com/subaru24covertype.aspx
Spool depends on which version (16G/18G/20G and size of turbine housing (7cm or 8cm)
Faster spool is less top end and vice versa ;-)
In a few of the Audi/Elise cars I've built I've used a few Mitsubishi TD05 18G's with a 7 cm exhaust housing. Very quick spool and pretty good power. Nearly makes the 350 BHP you are after.
Look for JAPWarehouse shop on Ebay.
