looking to get a vf35 what you think guys??
gtx28 will do the job!
IHI TD05 16/18/20G will also fit.
Nice options available for 400+hp and quick spool.....
Compared (from left to right)
K03-052 - k04-064 (TFSI) - TD05 20G (old cast style compressor and 12 blade turbine)
About same size as Audi TTRS 5cyl. K16...
Same size TD05 20G in standard compared with Billet wheel option and 9blade quick spool option:
Unconventional "underslung" style jabba sports manifold......
So if you are fine with 350hp, you will normally be good with the slightly smaller 18G compressor and have even faster spool.....
Where can I get a quick spool 18g from? When will boost kick in?
Manifold is from jabbasport (If you are lucky to receive a reply, I did not....)
Turbos can be had from Kinugawa:
shopping.kinugawaturbo.com
http://shopping.kinugawaturbo.com/subaru24covertype.aspx
Spool depends on which version (16G/18G/20G and size of turbine housing (7cm or 8cm)
Faster spool is less top end and vice versa ;-)
