That's what I've been doing. but it only stays secure for so long. I'm just using small blocks of wood to wedge it in place. Going to do that again to night. But make it a bit more secure. Hopefully get it fixed for good later on when I have more timeCan you not just secure it somehow
strip as in remove disc?They are prone to corrosion and break away from the mounts. Wedging it will have to suffice for now until you can strip and remove/replace them.
That's what I was thinking of doing mate. but need to know how to take disc off?Hey buddy. Had similar problem with my 2008 FR. Removed wheel, and disc. However, it's likely you'll need to remove hub, or cut dust plate out. I ended up using large washers to hold in place...
