Any one fitted hertz dsk 165.3 or esk speakers?
tundrarocks
323
Newcastle Upon Tyne
I've been using a rcd-510 dab for over a year now and I really can't get used to the treble. Anyone tried the same head unit or rns 510 with aftermarket speaker and have any recommendations ? I don't want to go down the amp and sub route as fund don't allow.
spud31
Rail Zip User
Jul 14, 2011
407
i would fit focal 165a1 as more sensitive so better under head unit power
AndyG_TSi
1,174
East Manchester
RNS-510, with VIbe Slick 6 -way co-axials in mine
Question, when you fitted your aftermarket speakers did you cut wire 2 (i think) on the adaptor wiring which came with the speaker adaptor mounts (SAK-3103)
If you didn't, you will have the tweeter at the top of the door & the tweeter in the 2-way speaker working at the same time - hence the high end sounds will be a little harsh
Cutting wire 2 will disable the original tweeter, there is a thread on speakers in the mk2 FAQ section whih tells you what to do
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
A speaker upgrade will work wonders , just be prepared to take the door card off to replace your tweeter , its not a 5 min job and patience is needed.
while your there i would advise dynamtting your door you wont need a lot but it makes a massive difference.
I put these http://www.jlaudio.co.uk/c5-650-car-audio-c5-speaker-systems-99104
in my front doors and they sound amazing , the bass is much beeter and tighter now.
tundrarocks
323
Newcastle Upon Tyne
Took the plunge and got a pair of hertz 165.5l. Chickened out on fitting them and glad I did! Took two experienced fitters all morning to get the passenger door card back on! Got the doors dynamatted too.
Only had them in a few hours but the difference is amazing.
Just wish I could have afforded to amp them at the same time
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
I did tell you that you will need patience for the door cards lol
How much labour did they charge you ?
Dynanatting makes loads of difference to the sound , your doors should have that nice solid clonk when shutting now as well.
tundrarocks
323
Newcastle Upon Tyne
It was around £40 labour. I really didn't want someone else to do it but I'd never have the time to do it myself.
Even after a few hours the sound really good. Don't think I'll get a sub but I do fancy amping them. Still can't make my mind up on what head unit suits my needs
tundrarocks
323
Newcastle Upon Tyne
I've read quite a few people lose bass when they change speakers but I've found I gained more controlled deeper bass. Treble is also more controlled and doesn't leave my ears bleeding!
tundrarocks
323
Newcastle Upon Tyne
Just hertz esk 165l speakers and dynamat. Did alter the settings of the head unit with vag com a while ago. Think if you set it to skoda you get even more bass and treble. Just set at linear at the moment
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
Visit site
^ tell me more,
i had my speakers out today, turns out i have vibe in the front (bassless) edge in the rear they have bass so switched them around :) i now have no tinny trebble
Jarre
5,365
11
Stockton-On-Tees
^ tell me more,
I have vibe speakers and they're definitely more bassy than stock speakers. I have a subwoofer as well, though, as there still wasn't enough bass.
tundrarocks
323
Newcastle Upon Tyne
Just took my door cards off to fix the noisey electric windows only to find the supposed audio installer had made a right job of it. Guess if you want a job doing right you got to do it yourself!
Bignod00
2,201
Lincoln/40,000 ft.
Apologies for an old thread revival. I'm looking at fitting the same speakers as you.......did you need to adapt anything to make them fit the doors etc.......my mate has said something about having to make some adaptors..????
