So had a bit of a tidy up in the shed tonight and removed some more parts off the engine
Have taken the crank seals off the block, removed the crank and oil filter housing just need to remove the oil squirters then it can go and have its rebore and clean up then give it a pick of paint ready for the new pistons
So once the squirters are out the block will be dropped off when I get a moment for a rebore and hopefully get my TFSI crank gear swapped over then just need the rods and pistons to go in
