Picking up the pace now bud! Well chuffed for ya! Bits that you're putting on now look awesome! Will be wicked when you can finally enjoy you're labour!!
Thanks Matey, really picking up pace now
Update Time
The other night i decided to do a quick job, re-bush the wishbones and stick them in.
Well that never exactly went to plan.
Dug the nicely powder coated wishbones out of the spare bedroom, look awesome -
Here's the parts that i used on the wishbones, not pictured all new genuine bolts & nuts -
I started of by cleaning out the over spray out of the bush holes, Weapon of choice... i used a flap wheel mounted in the trusty battery drill -
I then pushed the new front bushes in by hand, easy peasy lemon squeeze
Put some of the copper grease supplied lube in the pins / bushes then knocked the pins in with a rubber mallet.
Then i tried to get the rear rose mounted bush in... just gave it a tap around the circumference with a small hammer thinking i would just start it off then use the vice to push it in....didn't want to start so i decided to strip the bushes down so i could fit the bearing puller set through the hole in the middle and try pulling the casing into the wishbone.
Incase anybody is interested what's inside Powerflex black rose mounted bearings -
It's made up of a PTFE lined rose bearing which is held in place by two split poly bushes then a metal disc, then a cir clip.
After removing the innards i could pass the beefy threaded rod through the middle of the bush and try pulling the bush into the wishbone.... well that didn't work either. I used a 2 ft bit of pipe on the end of a rather large adjustable spanner and it pushed it in a couple of mm.
I then busted out the digital verniers and measured everything up. Found the reason it was so tight was the bush was 0.5mm bigger than the bore of the wishbone.
I messaged Tim on here and he confirmed he needed crazy amount of pressure (15 ton) in a press to fit his.
I know the bushes need to be tight in the wishbones but i've never in my Engineering experience had something 0.5mm bigger than the bore size to fit.
I thought about dropping the casings off somewhere to have the skimmed down but then had a moment of inspiration and found something ideal for the job.
I found an arbor for a cartridge roll set was a perfect fit for the ID of the bush.... mounted in the battery drill -
I then mounted the Drill in the vice and cable tied the trigger on (i just removed the battery to start / stop it).
I then used a fine flat file to reduce the diameter of the bush by 0.25-0.30mm.
Polished it up with some Wet & Dry 320.
I then applied loads of loctite to the bush and bore and using the puller equipment pulled the bush.... i had to use the adjustable spanner and a length of pipe and it fought me all the way.
I finally got the bush pulled into the wishbone and then called it a night.
Last night i got a few hours in the
garage and i built the bush back up -
I then noticed that the tapered inserts that fit into the rose bearing were sticking out different amounts on each side of the wishbone
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
So i re-checked the instructions and it does say to push the bush in until the inserts are centralised..... i really don't know why they didn't make the rose bearing mount directly in the middle of the bush casing.
I then did some measuring and worked out where the outer bush casing had to sit.
I had too push the bush back out which was crazy tight due to the loctite setting.
After getting the bush casing into the right position i then built the bearing back up, lower poly insert fitted -
Rose Bearing Fitted -
Outer poly insert fitted -
Then a metal disc -
To get the circlip fitted you have to compress the metal disc, i used a socket with a G-clamp to compress the poly the slipped the circlip into the groove.
Fitted them both... only torqued the bolts to the first stage, still got to angle torque them but i'll do it once i know they won't be coming back off.
So my nice easy job took me like two nights to fix
oh well your always gonna run into these problems when your building stuff.
Tonight i started on the hubs.
New parts going into them, i bought FEBI parts, German made
I then started cleaning up the excess paint from the hub, tapped the shield bolt holes out and used a dremmel to remove the paint from the ABS sensor hole.
I cleaned the hub bearing faces out, and cleaned out the circlip groove out.
I then selected the smallest ring from the bearing puller kit and it fitted like a glove into the back of the hub -
Mounted it in the vice to pull the bearing in -
All pulled in
Removed the puller assembly and fitted the circlip -
Next job was fitting the abs ring / wheel hub. I selected a spacer that sat nicely against the step where the driveshaft bolt sits.... Mounted in the vice -
I then found another spacer that was a good size to only press on the inner race. Pulling it in -
All done
Test fitted the coil over -
Found the bracket that sits in the split of the hub was not lining up with the bolt hole....
So i ground it out a bit with the trusty dremmel until the pinching bolt fitted with ease.
Pinch bolt and lower ball joint fitted torqued up to first stage, i used new OEM nuts and bolts rather than the ones supplied with the parts, i also used the powerflex grease on the upper strut and also the strut tower....
Ready to go in -
Installed but Crap shot of it, sorry the cars pushed against the wall... the only thing is the ARB drop link looks all wrong to me. May look better when the weight is on the suspension.
Tomorrow i get the drivers side done and installed.
Thanks for reading & any comments...
Graham.
