looks good I'm after a 312mm &2-4 pot calipers setup for my mk5 1.4tsi fr it's sitting on fr 16's atm with 20mm spacers at the rear and putting 10mm on the fronts. Could you sort me out ?
Sent from my HTC One using Tapatalk 2
Not sure if you will get the 4 pots under 16" wheels.
The normal 312 single pot caliper is really close to rubbing on 16" wheels - I guess you might need to go 17" wheels first.
I would see if you can find someone with 4 pots and see if you can get your wheels over them.
From the pics above I might actually have a 312mm set up on there. I'm not home atm so I can't measure them I'll check when I'm back from sea on Thursday. So how much do you think you could get me a 312mm set up single pot & 2-4pot if you could pm me some prices![]()
ATTENTION!!
You don't need Mk1 S3 or TT calipers to fit 312 mm disc anymore.
2013 Polo GTI's and Audi A1's have 312 mm disc.
You can buy a 2013 GTI caliper carrier and use your 2011 ibiza cupra/boc caliper on 312 mm disc.
So what the script with these setups ? What size is standard on my 2.0 tdi FR ? And is it a full setup I need ?
Got a rebuilt freshly Powdercoated red set of these with brand new pagid pads if anyone's interested
ATTENTION!!
i have sat in my garage some golf gti mkv calipers, carriers, discs and lines, are these possible to get onta a 6j ibiza 1.6tdi ??
