Mk5 Golf is 5x112
6j Ibiza is 5x100 is it not? In which case you wouldn't be able to use the discs.
cool so you think the calipers and carriers should fit ok?? if so ill get some discs ordered up
thanks for the info mate ill dig them out and measure them up tonight, as the brakes on the 1.6 tdi are pants, even more so now ive had the dpf removed and it mapped
You will not regret the 312mm upgrade - did it on my 2.0TDi.
The 312 is the setup that should have been on the car from the factory.
Even more so with the Brembo HP2000 brake pads I added at the same time.
totally agree!
stupid how boc/cupra did not come with this set up
so the discs id need would be from a 2013 polo gti??
so...
anyone can share the part number for the hubs to use any other calipers that aren't the FSIII?
Thanks mateDon't know part number but
Drivers side here
http://www.ebay.co.uk/itm/SEAT-IBIZ...arts_Vehicles_CarParts_SM&hash=item27edf00341
Passenger side here
http://www.ebay.co.uk/itm/SEAT-IBIZ...arts_Vehicles_CarParts_SM&hash=item1c476b9463
And for comparison - here is the FSIII version - http://www.ebay.co.uk/itm/2009-Seat...arts_Vehicles_CarParts_SM&hash=item4adf76f6f5
Note the two arms sticking out from the hub.
ATTENTION!!
You don't need Mk1 S3 or TT calipers to fit 312 mm disc anymore.
2013 Polo GTI's and Audi A1's have 312 mm disc.
You can buy a 2013 GTI caliper carrier and use your 2011 ibiza cupra/boc caliper on 312 mm disc.
