Easiest mod ever, literally takes less than 30 seconds to do both sides
Thank you
I've received mine (used the link from OP) and fitted on Saturday (very easy).
Might be worth chasing the seller up?
I also used the link from the OP (the guy should give him commission!). When did you order yours out of interest. The time estimated delivery window ends tomorrow, so will wait until then.
Just fitted mine, less than a minute and look to make a huge difference!
I followed the link from the OP and mine took 8 days to arrive (including weekend).
I used the original link and they arrived after about 10 days, took 1 minute to fit and made a huge difference.
Before fitting I adjusted them right up as I think they were designed for the Altea which has a steeper bonnet angle.
They do seem to freeze more easily than the jet ones, so stronger screenwash concentration required.
Hope they arrive as it is a quick and easy change.
Typically, the day I start talking about it on the forums, a certain package turned up whilst I was at work! Will fit at the weekend or maybe later today.
