will_0407
256
Just had my car washed and noticed that the felt lining on the inside of the window is wet on the front passenger side door.
Assume that means water has leaked/seeped through somewhere, any idea where this could be as it's confined to the bottom part of the lining as per the pic.
My windows look the same after I wash the car. I just assumed it was normal behaviour ie. water is getting behind the door rubber and wetting the felt due to spraying water at an angle.
Thanks for your reply, seems a reasonable explanation! Pretty sure the rain won't be firing into the door seals at the same rate the water does from a pressure washer so I guess nothing to worry about.
This happens to my Mk2 Leon everytime i wash it or after it's been raining hard.
I don't use a pressure washer just sponge and bucket and no matter how careful i am it still mists up like this. No big deal though it's nothing to be worried about
Sent from my android via Tapatalk
