yes and no
you cannot make a mechanically laggy setup spool at will...
forget the 400bhp figures from 2871, dream land
2500-3000 is better than the k04 is now ffs
your expectations of power vs spool are wildly at odds with each other
EFR twin scroll units have reputedly good spool and power but I have not seen one in the flesh to comment first hand (yet)
so the 2871 is not the right one
I have checked EFR and they seem good but as you said, i haven't seen anyone tried it yet
the thing is, not much people in my area would really understand and help regarding the turbo engines :cry: which makes me going for Turbo setup has been tried and recommended
my aim is a daily drive car with lots of power up to 400 HP but it seems i won't be able to do it without proper guiding and suggestions
as suggested before the GT2860rs would be good for my set up
what you think about that or you have a better common option ??? :shrug:
GT2860RS will do 330-350bhp with supporting mods, maybe a little more, but the spool wont be like you said, and what you said was faster than your existing k04 would manage also.
Does your car have a diff?
If not then your 400bhp number would be spun away majority of the time anyhow
As I said previously your wishes of spool are at odds with your power number
If you came to me for 400bhp I would be building a GT30 based setup
GT30 on tubular manifold, cams on rodded AUM engine example below
https://www.facebook.com/photo.php?...0285721678241.337309.748398240&type=1&theater
What is a diff ?
And im not running k04 at the moment, mine is k03 with AUQ engine code
Ill rebuild the engine, pistons, rods , valvs, to withstand 500+ hp
so i need a turbo set up that will take me to hight hp but faster spool
Let's say the boost will be from 2500-3000 rpm upto 7500 rpm
What do u suggest and what would be the max hp ill get ???
then I'll kiss the 400 hp good bye
what about if i use this configure
IE rods and pistons 82 mm with 8.5:1 CT
550 CC injectors, 044 fuel pump
Hyprid K04 with relentless equal length exhaust manifold
3 " downpipe with sport cat
and all the other things to add
will it take me to 350 hp ????
A LSD is possibly the best thing you can do to a high power FWD car, no point having lots of power and torque if you cant put it down and use it, I fitted a quaiffe lsd to one of my old cars, was the best thing I ever did.
I know that
but its gonna be too much money to spend
not worth it :)
Nor is everything else you're planning on doing but that's the joy of modifying cars. It's going to be pointless spending a shed load of money to get the power you want if you can't actually put that power down on the road
Thanks guys for all the tips
Im learning new things everyday
Sure will keep u all updated
And im sorry for giving u all headache asking many questions
Will start getting parts soon
Hope it works as expected :)
add wmi and "possibly" if mapped well
