ilknur07
23
Dear all. I am new here.
Recently I did some coding and some adaptation on my seat exeo 2012. After that welcome screen changed from seat media to Audi MMI. When I try to change it with VAG Com,but there is not any number for Seat
Channel 018: Start Screen
0 = Standard Start Screen
1 = Audi S3 Start Screen
2 = Audi S4 Start Screen
3 = Audi RS4 Start Screen
4 = Audi TT Start Screen
5 = Audi R8 Start Screen
Can anyone tell me how to change it to Seat Media System?
Any help would be appreciated.
Ilknur07
Ill try and find the default value for you later mate if no one else can help in the mean time :)
Thanks.
When I bought it was Seat Media Shown. After that I did some coding and adaptation it gone.
I heard that,need to be write seat log and change it to btm format. Then burn it on a new SD and insert to RNSE and it will be upgraded automatically. I tried but no success
Ilknur07
Have you looked in RNS_E engineering mode
1) Turn on RNS-E.
2) Press the NAV button and release.
3) Press the top-left cursor button for 5 seconds and release.
4) Press the top-right cursor button for 5 seconds. Hold until the screen changes
I remember seeing something in here before I changed my RNS-E
Regards
1) Turn on RNS-E.
Regards
Thanks mate.
I tried to do something but no success
Regards
Thanks lm62svt
I went to Engineering Mode,but could not do anything. Is there anything to be changed or activated? Please tell
What does the this mode do?
What can you do with the Engineering Mode screens? Any useful functions that can be turned on?
Thanks mate.
I did some changing on SDS under GENERAL on Engineering Mode, but stil AUDI MMI showing on welcome screen. When I bought it was Seat Media.
ilknur07,
Have you got vcds (vag com ), check the code on your unit, mine is coded 0319757.
might be worth a look to see if you have changed it.
kev
ilknur07,
kev
Thanks kblackburn
I changed the code as your,but no success with vagcom
I heard that there is specially program to find seat logo and burn a CD. Then insert the the cd to rnse and let it to upgrate itself automatically,but I have not found it yet
Ilknur07
Ilknur07,
do you have an auto scan of the radio ?
if so could you post t up
thanks mate for your reply.
this is 2013 made RNSE for Seat Exeo. I do not know it has auto scan or no. How can I check it? Please let me know
Chassis Type: 3R - Seat Exeo
Scan: 01 02 03 08 09 10 15 16 17 25 37 36 45 46 4C 55 56 77
VIN: VSSZZZ3RZDR002626 Mileage: 25910km/16099miles
Address 01: Engine Labels: None
Part No SW: 3R0 907 115 G HW: 3R0 907 115
Component: 2.0l R4/4V TFSI 0020
Revision: 5EH18--- Serial number:
Coding: 0304001002070120
Shop #: WSC 06441 785 00200
VCID: 336F0115522E491
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No SW: 8E4 910 156 M HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI RdW 0010
Revision: 00000012 Serial number: 00000002075740
Coding: 0000002
VCID: 346D020957204E9
Address 03: ABS Brakes Labels: None
Part No SW: 3R0 907 379 HW: 3R0 614 517
Component: ESP8 FRONT H06 0050
Revision: 00000000 Serial number: 00000000000000
Coding: 0004360
VCID: F8F576398BC8EA9
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 06441
VCID: 6CDDDA691C90D69
Address 09: Cent. Elect. Labels: None
Part No: 3R0 907 279
Component: int. Lastmodul ECE 0204
Coding: 01021
Shop #: WSC 06441
VCID: F7F77505D5D6E51
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 3R0 919 475 HW: 8P0 919 475 M
Component: PARKHILFE 4K H08 0005
Revision: -------- Serial number: 36861217500984
Coding: 000001
Shop #: WSC 09549 001 1048576
VCID: F8F576394BC8EA9
Address 15: Airbags Labels: 3R0-959-655.clb
Part No SW: 3R0 959 655 HW: 3R0 959 655
Component: 04 Airbag 9.41 H15 0010
Revision: 91H15001 Serial number: 003E90027BUX
Coding: 0012340
VCID: FCFD6A29BFF0C69
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0902
Coding: 03141
Shop #: WSC 06441
VCID: 41835BDD4B92EB1
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 3R0 920 800 K HW: 3R0 920 800 K
Component: KOMBI+WFS 4 H06 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0006118
Shop #: WSC 42900 429 12275
VCID: 336F0115512E491
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006118
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 3R0 035 192 HW: 3R0 035 192
Component: RNS-E PU EU SP H05 0700
Revision: 0000011S Serial number: SEZBZ7K6901501
Coding: 0311755
Shop #: WSC 00000 000 00000
VCID: E9D3237DC362431
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Time Indication: 0
Date: 2015.01.28
Time: 10:38:54
Freeze Frame:
Mileage: 655350 km
Count: 2801
Clock: 10:38
Address 46: Central Conv. Labels: None
Part No: 8E0 959 433 CN
Component: Komfortgerát TA7 4436
Coding: 06768
Shop #: WSC 42900
VCID: 7F071D257DE65D1
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
4 Faults Found:
01561 - Left Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
01562 - Right Rear Door
Address 4C: Tire Pressure II Labels: 3R0-907-274.clb
Part No SW: 3R0 907 274 HW: 3R0 907 274
Component: J793 RKA+ H04 0002
Revision: 00000528 Serial number: 00005280180242
Coding: 0000577
VCID: F2E14411EDB4809
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 D HW: 5M0 907 357 D
Component: AFS-Steuergeraet 0149
Revision: 00H04000 Serial number:
Coding: 2753613
VCID: 356B3F0D5C5A571
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul l 0004
Coding: 00000042
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul r 0004
Coding: 00000042
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0311755
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Time Indication: 0
Date: 2015.01.28
Time: 10:38:54
Freeze Frame:
Mileage: 655350 km
Count: 2801
Clock: 10:38
Address 77: Telephone Labels: None
VCID: 55AB9F8DBF1A771
Note: Excessive Comm Errors
End ----------------------------------------------
ilknur07,
Hi,
when you said you tried the same code, that mine is coded too, did you then go to adaptions, channel 18, I think you need to add 9 to the list and you also need the nav dvd installed, as that's where the info is for the start up screen.
kev
ilknur07,
Hi,
kev
Thanks Kev
That is why I am asking how I can get that DVD,or Can I bun it. I do not know exactly.
Please direct me to find it.
ilknur07
