[GARMIN PID] Garmin Mod&Skin-Tool [Reverse Engineering]
robomrburns
82
Early Access!
This thread is a log of how far I got building my own application and reverse engineering the Garmin PID.
If you like you can download VW_UserShell_SeatSkin.nfs and replace it in your VwUsershell Folder.
Skin:
TOOL:
This is a tool to quickly switch between Performance and ECO Trip:
Extract zip, then copy the folder to the internal Storage /Apps/ .
In addition you need edited Watchdog.ini files otherwise your device will just reboot.
NEW Skin Release with tool to change them on the fly!
Download
Non Cupra Perfomance activator by me (EXE Only):
Total Commander.
It replaces the Manual Reader
http://www71.zippyshare.com/v/Fhb871B6/file.html
Android App Development:
Using a Bluetooth Interface.
App screenshots coming soon
Credits for the skin tools I used go to @Pher. Thanks!
robomrburns
82
Things I am working on as of now (16.02.2016)
Rerverse Engineering the Dataprotocol (making some slow process on BAP and CAN)
Theming the device (on hold, more important stuff to do)
Developing on the Device (on hold until Android app works)
Adding Support for other Cars (Need your help for that)
Building my own Device (Based on Lenovo Tab 2 A7-30H)
- Making connection via Wire (worked well, but bluetooth is the way to go)
- Using bluetooth now (Works well now. OPAmps are used to Levelshift)
- Devloping Android App ( making good progress)
- 3D Print a Housing and Holder.
robomrburns
82
Rev
Does this work with what models? And how does the rev counter look (where is the redline etc)?
It looks like that:
Exactly like the normal IBIZA 6J.
But I think Ill redo all of the gauges because I was able to extract the font from the system.
It's only testet on my Ibiza, it schould work with every Ibiza except Cupra.
Please be patient with me, a Cupra version is in the making.
Pyrres
Ibiza Cupra -14
May 2, 2014
299
Finland
Yeah, no worries mate :). Just asking as I lf course need tue Cupra version and the models were not mentioned in the initial post.
x9moto
80
your mods are amazing i have installed them all! please tell me where the link is for the skins you mention as i cannot find it, thanks
Mat.
robomrburns
82
Sorry I had to remove them, because they are not compatible to v 7.16.8.
maybe I find time soon. I still have all my skinned files, so it's not that complicated..
robomrburns
82
Download
Enjoy!
The Phone Application and the Navigator will be skinned soon.Sffn/file.html"]Download[/URL]
robomrburns
82
found a small issue, where it does not pair up again with your phone after standby. The solution is simple:
In the Watchdog_BTCore.ini change ActionAtTermination = 0 to ActionAtTermination = 2
Pyrres
Ibiza Cupra -14
May 2, 2014
299
Finland
I had that same issue. Always had to reboot the device to get bt to connect.
dps5pt
Thank you.
Works for me Ibiza FR accept the G-force.
Grtz, Adrie
The car movement on the Eco-trainer (slowing and accelerating detection) suggests the FR has some kind of accelerometer, which i assume is the type of sensor the G-force function uses. Have no clue as how that could me made to work though...:confused:
teserinen
Hello robomrburns,
You have done a good job with SPS, thank you. I want to ask you if is possible see the same guages in ECO Trip mode as Performance mode.
It will be nice if we can choose the boost gauge or consumition average gauge in ECO Trip display.
Pyrres
Ibiza Cupra -14
May 2, 2014
299
Finland
Car can calculate that from inputs like speed sensor, steering angle etc. G-force detection needs a better suited sensor for that.
