VAGCom
chrisoverson
13
Found it, cool, I have a Bluetooth adaptor already, what have you changed on it alredy?
Here's a full list of the options it allows, the only thing I haven't got working yet is the remote keyfob window up/down (would be really nice to have) but I haven't tried too hard as it's raining outside.
The starred ones are the ones I have selected :)
Doors / Windows / Remote:
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Unlock trunk when doors are unlocked
*YES* / NO
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking with remote
YES / *NO*
Beep when unlocking with remote
YES / *NO*
Beep when alarm is armed
YES / *NO*
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
YES / *NO*
Open/close windows via long-press on remote
*YES* / NO
Open/close sunroof via long-press on remote or key
YES / *NO*
Open sunroof via long-press on remote
YES / *NO*
Close sunroof via long-press on remote
YES / *NO*
Open/close windows by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
YES / *NO*
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Enable remote control buttons when ignition is on
YES / *NO*
Instruments / Display / Dings:
Lane-change turn signal auto-flasher
*ENABLED* / DISABLED
Lane-change turn signal auto-flasher count
1 FLASH / 2 FLASHES / *3 FLASHES* / 4 FLASHES / 5 FLASHES
Lights:
Daytime running lights
Allow configuring daytime running lights via dash display
*YES* / NO
Coming-home lights (req. auto headlights or manual flick of high beams)
Leaving-home lights (req. auto headlights)
Coming/leaving-home lights use…
LOW BEAMS / *FOG LIGHTS*
Coming-home lights duration
10 SECONDS / *15 SECONDS* / 20 SECONDS / 25 SECONDS / 30 SECONDS / 35 SECONDS / 40 SECONDS / 45 SECONDS / 50 SECONDS / 55 SECONDS / 60 SECONDS
Leaving-home lights duration
Turn off front fog lights when high beams are on
YES / *NO*
Turn on interior lights when key is taken out of ignition
*YES* / NO
Flash brake lights in emergency stopping
YES / *NO*
Flash hazard lights in emergency stopping
*YES* / NO
Brake lights work even when ignition is off
*YES* / NO
"Euro" parking lights when ignition off, turn signal on
Other:
Activate side mirror heaters when rear window defroster is on
YES / *NO*
Automatic wipers (using rain sensor)
Speed-dependent windshield wiper speed
YES / *NO*
Additional 'tear' wipe after windshield washer use
YES / *NO*
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Horn works even when ignition is off
YES / *NO*
Reactions: Joe_3490
irl_techie
58
Great, thanks.
Dont think the auto up windows will work though as the Drivers side window is the only one that is Auto.
I would love to be proved wrong though :)
chrisoverson
13
Great, thanks.
I've tried different combinations of the settings but nothing I do seems to make the auto up windows work :(
Other than that, it all looks pretty good! If they added dial staging that'd be pretty much everything covered haha although that's totally for looks and not necessary.
Quite impressed that the coming home lights work, although the leaving home ones won't as there's no light sensor.
I haven't actually tried it in the dark yet though...
chrisoverson
13
That s why you can get big MPH - we can't.:( without VCDS
I want it! :p
I've been chatting with the guys that do Carista, hoping that they can add some more features. Apparently they're working on dial staging and should be implementing that soon, but I don't know about the region etc. They have that enabled for the Polo I think so fingers crossed.
camelspyyder
2 SEAT-er
Jun 26, 2014
1,305
175
Are any of the other android OBD tools any good? I saw at least a dozen when I searched Google Play last night.
Bluetooth adaptors ar only $10-15 over here. I think I'll get one and try it out when I get back to the UK in the summer.
chrisoverson
13
Only other one I like really is Torque Pro. To be honest it's not all that pretty looking and is a little fiddly to set up but very good when you've got it how you want it. The fault reading etc is great as well, and can clear codes etc.
This Carista app is the only one I've seen that lets you customise the features on the Seats etc though properly.
irl_techie
58
Chris, what really would be a cool feature would be to be able to turn off the Bluetooth Pairing Bell !! :)
camelspyyder
2 SEAT-er
Jun 26, 2014
1,305
175
Nobody near me in Ireland from what I can see :(
OK - Irish VAG site here with massive list of VAGCOM Locations :)
http://vagdrivers.net/forums/index.php?showtopic=41765
11 of the initial list alone in Co Cork!!!
A few Irish VAGCOM guys on here:
http://m.vagoc.co.uk/vb/showthread.php?t=122
Alternatively any of these Briskoda members any good location wise?
Northern Ireland
Bangor = DougL = Micro-CAN
Coleraine =blobbyp = HEX+CAN
? = Badger Driver = HEX+CAN
Ireland
Co. Mayo = pdhealy
Dublin = bpm
Dublin (Lucan) =mcsweeney = HEX+CAN
Dublin = Shahoff = HEX+CAN & EDC16(+) firmware reader/writer
