Its plenty loud enough! I personally want to hear induction/mechanicals over exhaust noise and More to the point it's free flowing for stage 2+ , at which point Id Definetly wanna be listening to the induction/mechanicals
And if you want a test dummy give me a shout, you can follow in mine
I'll volunteer mate but can't guarantee i won't kill your clutch :whistle:
Haha, im sure you would be gentle with her ;)
Yeah I do love the induction sound. ;) cheers for the offer I might well take you up on that mate.
Good look for the MOT fella she will sail through I'm sure. Looked in good order on the ramps :)
Cheers mate. Just dropped her to the garage. Guy said 'oooo that's a nice one..'
Ive taken a photo of the trip ;) Nah I trust my local garage - just paranoid about leaving it anywhere.
Put it on the standard map, hope that was a good idea.
Aaaaaand MOT was an easy pass. Phew.
The guys in there loved the exhaust, and the car, nice little boost for the day ;)
Good to hear she has passed no issues buddy.
Yes I'd say it was a good idea to return her to stock mapping. To be fair though he won't be driving anywhere as it's just the MOT.
I did afterwards though ;)
Hadn't driven anywhere since bank holiday Monday!
I hope the weekend weather holds out like this week, I see some cleaning and GoPro-ing if I can.
See if I can kill the clutch - I wanna be in the Helix uprated gang!
Not really!!
Not really!!
Ha ha it will happen at some point mate that's a given :cry:
Got my OBD dongle, Carista app, all worked very nicely.
Had a go with Torque and that seemed fine too.
Also good news no error codes present after a full scan using both apps.
It mentioned a few things it couldnt connect with, like back doors, but no problems reported.
Got needle sweep enabled and a few other bits amd bobs.
For some reason I thought you could disable the cornering lights but I cant see it in the list.
Here's my options
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote:
Auto-lock doors when moving
***** *YES* / NO
Auto-unlock doors when key is taken out of ignition
***** *YES* / NO
Auto-lock trunk when moving
***** *YES* / NO
Unlock trunk when doors are unlocked
***** *YES* / NO
Blink turn signals when locking/unlocking with remote
***** *YES* / NO
Allow configuring beep when locking/unlocking
***** *YES* / NO
Beep when locking with remote
***** *YES* / NO
Beep when unlocking with remote
***** *YES* / NO
Unlock doors via remote
***** DRIVER'S DOOR ON*1ST PRESS, ALL ON 2ND*/ *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
***** *YES* / NO
Open/close windows and sunroof via long-press on remote
***** *YES* / NO
Open only driver's window via long-press on remote
***** YES / *NO*
Open sunroof via long-press on remote
***** YES / *NO*
Close sunroof via long-press on remote
***** *YES* / NO
Sunroof action when opening via remote
***** SLIDE / *TILT*
Open/close windows and sunroof by holding key in door lock
***** *YES* / NO
Blink turn signals when done closing windows via remote
***** *YES* / NO
Enable remote control buttons when ignition is on
***** YES / *NO*
Instruments / Display / Dings:
Instrument cluster region (affects ext. lights too)
***** GERMANY / EUROPE/OTHER / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Gauge needle sweep at startup (req. instrument cluster support)
***** *YES* / NO / NOT AVAILABLE
Seat belt warning
***** *ENABLED* / DISABLED
Lane-change turn signal auto-flasher
Lane-change turn signal auto-flasher count
***** 1 FLASH / 2 FLASHES / *3 FLASHES* / 4 FLASHES / 5 FLASHES
Lights:
Allow configuring daytime running lights via dash display
***** YES / *NO*
Use designated DRL bulbs as daytime running lights
***** YES / *NO*
Use low beams as daytime running lights
***** YES / *NO*
Use fog lights as daytime running lights
***** YES / *NO*
Turn off daytime running lights ("wink") when turn signal is on
***** YES / *NO*
Turn off daytime running lights when parking brake is on
***** YES / *NO*
Coming-home lights
***** ENABLED / *DISABLED*
Leaving-home lights (req. auto headlights)
Coming-home lights mode
***** *MANUAL: FLASH HIGH BEAMS TO ACTIVATE* / AUTOMATIC: WHEN IT'S DARK (REQ. AUTO HEADLIGHTS)
Coming/leaving-home lights use…
***** *LOW BEAMS* / FOG LIGHTS
Coming-home lights duration
***** 5 SECONDS / *10 SECONDS* / 15 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
Leaving-home lights duration
Turn off all lights when headlights are left on and ignition is switched off
***** YES / *NO*
Turn off front fog lights when high beams are on
***** YES / *NO*
Turn off rear fog lights when high beams are on
***** YES / *NO*
Flash brake lights in emergency stopping
***** YES / *NO*
Flash hazard lights in emergency stopping
***** *YES* / NO
Brake lights work even when ignition is off
***** YES / *NO*
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
***** YES / *NO*
Auto-enable rear wiper when front wipers on and reverse gear engaged
***** *YES* / NO
Auto-enable rear wiper when front wipers on (interval) and reverse gear engaged
***** *YES* / NO
Auto-enable rear wiper when front wipers on (continuous) and reverse gear engaged
***** *YES* / NO
Additional 'tear' wipe after rear window washer use
***** *YES* / NO
Obtained with Carista 2.2.1 for Android.
Download app:*https://play.google.com/store/apps/details?id=com.prizmos.carista
Facebook:*https://www.facebook.com/caristaapp
Sent from Samsung Mobile on O2
Is the needle sweep the start up needle dance jobbie ? Have you got corner lights ? Thought they where xenons only
Yes it is mate. I now have a fancy beep when I lock the car too.
You can see all the options above, would be the same on your R mate. Let me know if you want anything changing.
No all vag cars have that thing where the left or right fog lamp comes on when cornering. Looks gash.
Ha that explains the fog light on in one of my pictures, again thought it was fault . Yeah you can turn that off for me . Oh a nice beep you say .......... You busy this weekend
Everyone seems to be doing really cool mods - im getting envious!
Here is an ultra subtle one, installed my replacement oem Cupra knob and gaiter..
This means my old one is now spare. Apart from the annoying mark on the badge which made me change it, its in great condition and probably looking for a new home.
Oo that'll definitely make it .01second quicker around croft:handbags:
I'm probably a minority, but. Quite like the R/C look of the standard aerial[B)]
Ain't seen one of those steering locks in years, Southerners :whistle:
