stop/start?its a pita and as soon as I find someone who can disable it, I'll do so.
it is a pain but for the time being, as you may've found out, if you're judicious with the brake pedal, ie holding just enough pressure to prevent the car rolling, the stop/start won't activate![]()
Ours is manual but I know what you mean.it is a pain but for the time being, as you may've found out, if you're judicious with the brake pedal, ie holding just enough pressure to prevent the car rolling, the stop/start won't activate![]()
I just need to find some kind soul near Brum who can do it......It can be done by VCDS, I've done it on my dads Golf, and it works a treat.
Careful, I've been told by my technician that such practice can cause premature wear on dsg boxes.it is a pain but for the time being, as you may've found out, if you're judicious with the brake pedal, ie holding just enough pressure to prevent the car rolling, the stop/start won't activate![]()
Not mine, if I touch the brake lightly it stays in gear. I have to properly press the brake for it to disengage.The car goes into neutral with a light touch of the brake. When you let go of the brake you can feel the gear initiate.
I've only ever run my Leon on Tesco momentum 99.
I look at it as follows;
I'm not mithered about any alleged performance improvement claims regarding super unleaded fuels, but I am interested in the benefits of the extra cleaning properties to the fuel system components that the super unleaded fuels give.
I could buy ordinary unleaded and then chuck a bottle of fuel additive in, but what's the point when the fuel you can buy does the same thing.
So for sake of a couple of pence if you can care for the engine internals and prolong the life of the car & keep it sweet, it's a couple of pence worth paying![]()
Try it out, leave your car in D on a traffic light and watch the rpms while barely touching the brake, just enough to stop the car. Do the same with the brake properly pressed and notice the rpms. It's the car declutching.
Yea I mean I really have no intention of scaremongering or anything, just be aware of how far down you have to brake for the clutch pack to disengage vs how lightly you have to press for the start stop not to kick in.thanks for the warning, i'll have a look on the next drive. only noticed rpm drop at a standstill in Sport mode but that was only after shifting the lever from D to N.
So.......what are peoples thoughts on perfomance diesel fuel??
This is my first petrol car for 6 years, previously had 3 Ford Kuga's all diesel, I found out very early on with Kuga no 1 that Supermarket diesel made the engine rattle and was a bit hesitant. I changed to BP Ultimate diesel and the engines on all 3 Kuga's ran a lot quieter and smoother. My wife and daughter have Ford Fiesta'a which only ever have Tesco Momentum in them and I find that they run better with no flat spots etc so my FR 150 ACT is also using Tesco Momentum and runs very well, I had a recent fairly fast trip back from Southampton on the weekend and although the car has only done 820 miles the computer was showing an average of 45.8 mpg which I am very happy with. The slight extra cost with premium fuel is nothing if the car runs better and hopefully will help in the long run by keeping the engine running at it's peak![]()
no problem, im not viewing it as scaremongering, if im doing something wrong it's best to know about itYea I mean I really have no intention of scaremongering or anything, just be aware of how far down you have to brake for the clutch pack to disengage vs how lightly you have to press for the start stop not to kick in.
I personally hate the start stop and I seriously believe it is hazardous when you have to enter traffic fast from a standstill, but that's just me![]()
