Never thought of a centre exhaust with a triple r defusser' was going to get the exhaust done after fitting the defusser too
OriginalSince2010
I don't think the Triple R diffuser can be used with centre exhaust setup (aka Cupra R), without major rework.
Yeah that's the diffuser I made myself, second one also. Now ive moulded the second type and reproduce them for the local guys.
Is yours a full plastic mould, clips and all?
Anyone else had a problem with the rear diffuser being to small, mines leaves a 1/2 inch gap on the right hand side
At least 2 month for a rear diffuser' as trying to sort the problems in between work load etc, ordered a front one instead today, suppose I can wait for a rear for a few month especially if it gets delivered and the quality is 100%
If you bond it and trim the left fin like I did you won't have that issue - before I did that it appeared too small as it didn't fit properly.
