Good luck,
Not wanting to add depressive negative thoughts, but if its that tight then it may be that the filter hasn't been changed in a long while. i.e. if the previous owner couldnt get it undone they may have just changed the oil and not bother with the filter. then another year of drying out and heat cycling making it even harder to remove. I wouldnt totally trust a
garage to be truthful either if they struggled to get it off and decided not to bother but not tell you - I personally have had many experiences with all sorts of garages (including very reputable places) where I have had good evidence and suspected short cuts.
I would go with teh deeper tool rather than trying to break the cap cos even if you break it, if the thread is that tight on the oring seal then I would suspect the brittle plastic cap will disintegrate (obviously potentially dropping hard bits into the oil filter housing ) but also I would suspect the threaded part will stay intact and still be as tight, and then even harder to remove as no cap to lever on, meaning you may need to find a way of cutting through the plastic to the thread risking more cuttings in the oil and also risk of damaging the thread of the casing. If you can avoid purposefully breaking the cap i would recommend that (obvious I know - but I think even as a last resort breaking the cap may be still very difficult and problematic to finally get the threaded part out.
Good luck, i'm sure you will get it off soon.
Moz
Thanks Moz mate, not taken that way either haha!
I had actually had this thought crop up a few times to be honest, because there is no way it should be this tight not after just a year gone by. I'm a strong believer in my own gut instinct and my gut instinct has been telling me that it's been skipping when I had the full
service done when I bought the car in honesty. Though with knowing next to nothing I would have been very easily mislead and fooled in to believing it was done.
I've got the breaker bar and the deeper cup wrench tool, both marked as dispatched as of 15/07 estimated delivery for them are separate. One for today and one for tomorrow, though both only estimates so if I'm lucky both could arrive today, if not sometime next week!
Either way, sooner the better so I can replace this oil filter asap!
I'd rather stay away from damaging the cap, that's one route I really don't want to take at all, once I'm done with this oil filter change I'll be having a new cap on the way from Dave at Sere and my next interval will include the new cap!
Again, thanks mate and it will DEFINITELY come off soon! :grin:
Unfortunately I don't own a pair of these, though I'm not positive it would do me any good!
Cheers for the suggestion though matey!
when i first did an oil change on my leon that cap was seriously tight,getting the engine upto normal operating temp helped allot, i only hand tighten it now with the cup removing tool and wrench, got a torque wrench but never used it.
Cheers mate, I've even had the engine up to normal running temps after a blast down to and back from Kidderminster, didn't budge one little bit.
Random and out of the blue Nam mate, but where about's in Atherton are you from? I'm originally from up Tyldesley mate haha, I wouldn't be surprised if you know someone from my family being up that way!
--Lee
