Going by this tuning guide: Link
I have seen for a stage 2 map I will want an uprated DV. I have read the 007p is the one to get, but I can't seem t find it. Is this 008p it's replacement? Or maybe this?
I currently have a FMIC and 80mm cone atm. I will have an exhaust manifold and 3" exhaust set up (With decat?), will have uprated rods. Is there anything else I am missing? ideas on required spark plugs? I'm thinking colder spark.
Cheers, Ash
Yeah i'm pretty sure for stage 2 you need to go a grade colder on the plugs.
The 008 is the replacement for the 007 as you say mate, the adjustable one just has the vacuum connection at 90 degrees rather than vertical as in the 008.
No mate, none performance wise. It's just for if you are trying to fit it into a tight space and the pipe is getting in the way. Shouldn't be an issue on the leon as there is plenty of room above the valve, think it's mainly for people doing engine conversions and trying to squeeze a 1.8T into a small car etc etc
I See. Cheers.
Are these eagle rods?:
Thats exactly what I did!
Right ******* to find.
However, someone who did know, told me they are...
Finger crossed this goes well. I hope the turbo is okay!
