Cupra 280 sound
Wings988
509
60
Derbyshire
Is the louder in cabin engine sound when in cupra mode fake/synthesised and how is it transmitted into the car?
:santa:
Snah
250
Netherlands
It is 100% fake.
It is an electronic sound generator that is situated under the bonnet below the right screen wiper.
I disabled it by VCDS because it sounds terrible.
Now I can hear the engine noise as it should sound and it is not bad at all.
Wings988
509
60
Derbyshire
I thought it might be, doesn't sound good at all but I prefer the throttle response in cupra mode. Can main dealers turn it off using the vcds?
Is the sound coming from the speaker in the top centre of the dashboard? I don't seem to here any music sounds coming out of it ....
Wings988
509
60
Derbyshire
Ok sorry I was thinking that the under bonnet device was like a sound generator or micraphone type device that fed the sound into the car through the speaker. Can it just be unplugged without showing any faults?
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Pretty sure it can be, certainly the one in the mk2 can.
Fmxvxx
387
It will still log a fault code so make sure to plug it back in before doing any warranty work other wise the tech will end up cursing you after going down a rabbit hole chasing the fault to find you've unplugged it and it's unrelated to the issue you brought the vehicle in for.
But if you wish to unplug it it's a fairly simple process
Remove the O/s + n/s Wiper arms 2x caps 2x 13mm nuts
Remove rubber trim around the scuttle panel, remove the scuttle panel 4x clips I believe
The control unit is located on the drivers side near the top mount follow the wiring to a small sensor about midway along the bulk head and unplug the sensor (make sure to tape the sensor up to prevent any water ingress into the loom)
Snah
250
Netherlands
It will nog generate a fault btw.
But when you have someone with VCDS in your vincinity it is easier and quicker to turn the volume there to -0-, no hasseling under the bonnet needed.
I also disabled start-stop by VCDS so the annoying things are switched off here.
cupriki
My dealer told me a flap was opened in the exhaust... Jesus miss-selling or what.
GrahamFR
Now AMG Powered
Dec 10, 2008
4,235
Barnsley or Burton
The first dealer I went to told me the same thing ...lol
thats on the golf R and S3
also, you can now change it on here:
so maybe you can find away of activating it on vcds for you lot
Porker3
83
Disconnected mine toda, at low speeds it didn't bother me too much but it's just annoying at motorway speeds. Only takes 5 minutes and you don't need to take the wipers off. Once you've removed the 5 fixings for the scuttle it lifts up far enough to get your hands in. The sound box can be released from the cradle it sits in to make it even easier to unplug. The car sounds much better now!
