It just so happens I do! You obviously won't be using a heat gun so I would apply with a small amount of water. Fill a bottle with water and one drop of washing up liquid . The bottle needs to have one of those nozzles at the top so that you can adjust to apply a light mist. You don't have the required tool for application but I would use a small squeegee (rubber or plastic) to apply the vinyl. Gently work the vinyl onto the panel using the squeedgy pushing the water out as you go . A blade is handy too for cutting off excess vinyl. If you have a
garage I would recommend doing it indoors , it's too cold to apply outdoors , the vinyl won't take, but still can be done if the sun comes out! What are you wrapping?
