225/45r18 in Leon 5F
Dt-spd
246
Rugby
That's the standard 18" size isnt it ??? Not sure what you are asking.
Got Bridgestone S001 on my summer wheels and Pirelli SottoZero S3 on my winter wheels, all in that size.
Curtly
893
19
Essex
The 18' have a 40mm profile I think he's asking if anyone is running theirs on a thicker tyre
MyLeon
349
It would make your speedo under read!
2015 Leon ST FR 184 DSG
C_ED_99
263
28
Nope standard tyres on 18" wheels on the FR are 225/40 R18
See the quote below - it's a percentage -
That 40 or 45 is profile number (% of width), not real tire height in mm.
This, the step up from 225/40R18 to 225/45R18 is about ~12.5mm on the tyres radius, or ~25mm (~1") on diameter (which then affects the tyres circumference)
It would make you speedo under read by about ~3.5%, so not the end of the world, it's about ~2.5mph at 70mph (ie your speedo says 70mph and you are doing ~72.5mph). Although all recomendations I've heard are to stick to <2.5% difference in size.
Mk3 Se
42
If you changed from the OEM tyre size you would have to inform your insurers.
There is about a 3.5% difference in overall diameter thus your speedo would be affected by that amount. If your speedo currently over reads by less than 3.5% (5% is normal) you would find your speed under reads with the 45 profile tyres which is illegal.
Think its fair to say Seat have spent countless millions developing the cars and the specs and any changes are unlikely to improve the car.
If you want 45 profile tyres you will need to change to 17" rims and still inform your insurers.
Don't forget that mods can affect the warranty.
