TI KUFF
83
I have noticed my right hand side low beam is facing too low.
I have changed my H7 bulbs about 3 times in space of 6 months trying to find the right light colour :D
But after all that fiddling around I think it has moved the light adjustment.
Well once my father did knock the beam out of its place while installing the bulbs
Anyway.. so how do I adjust my headlight. Apparently I heard there is white/creamish screw that you have to turn is that correct. Where do I find that screw, where is it placed? on top of the headlight/behind the headlight?
I would have taken it to garage but I would like to do it myself and learn.
There are two on top of the headlight, one adjusts the reflector left/right, the other up/down. Just need to use a Allen key, about 6mm or similar size.
I managed to move my right hand side headlight up, but I can't move it to the right as theres only one adjustment for the low beam headlight.
Other adjustment is on top of the high beam which moves the high beam up and down.
Any ideas where the adjustment is to adjust the light left/right
I will upload a picture just be clear.
Is this correct?
If so. How do I adjust my headlights left/right? I also used a phillips screwdriver to adjust worked well for me.
Because what I realised is after adjusting my right low beam headlight up, right low beam is too much to the left.
Will also upload a picture of my headlights beam, while sat in the car.
Those white bits are the adjusters, one is left/right... Turn it one way and it goes right, the other way makes it go left. The other screw dies the same but for up/down.
If an Allen key doesn't get through the hole you can grip the White bit with pliars.
Thanks bud it worked, just got around to do it.
